Sorry about that, I really need to fix that. In the meantime the workaround is to run it as admin. You can right click and choose properties and set it to run as admin if you want to run as admin every time. Or maybe you can just run it as admin when you want to edit the config.
I removed the program, re-install with resetting the config file and copied my settings back. I get the same thing. I then re-arranged the order to see if it only happens on cameras 1 and 2, I moved them to 3 and 4, but they still only show a still image. Hmm, maybe I need to reboot my cameras. I'll do that tonight and let you know.
Is it somehow possible, to implement a "little tour", that cameras and/or presets changes within this one windows window?
Options:
Showing time: x seconds (eg. 3 seconds)
Camera: X; Preset: X
Camera: Y; Preset: Y
Camera: Z; Preset: Z, ...
Playbutton
Stopbutton (or ESC) should stop at the actual view
