Thanks for your reply. I suspected that HDVCI cameras don't support IVS, also because they are built 2017, and at that time I even never had heard about AI.Those are HDCVI analog cameras. They dont have IVS
Your XVR "might" have it and usually limited to I believe 4 rules
Regardless, my opinion on your original question is to use h.264.h, bitrate no less than 4096, 15FPS, record full time (green) PLUS motion and or IVS, check and record snapshots, and see what you get as far acceptable coverage and storage. I'll guess 14-21 days
If however your sole focus is on storage and not image quality or capturing the many things that may happen before or after your motion event gets recorded (which wont always be as precise as you imagine) you may want to consider a simple trail cam instead of an NVR and cameras.
So, even in case my XVR has the setting, it still won't work?
I also have been reading up on motion vs IVS, and it seems the former option is less reliable, especially in my case where there are trees in the picture. I also understand that snapshots are recorded on an internal SD. Any idea what the limit of that SD card is?
