Hello
Has you know, firmware V 3.3.x doesn't support telnet operation (no more activation check box by gui),
so i'm asking if it as possible to do some telnet operation by serial port by putty even option disappeared.
But DS-7616NI-E2/8P doesn't have serial port RS232 on back, otherwhise it could be possible
directly on the logic board ?
Here is a my logic board, from DS-7616NI-E2/8P may 2015 production, does is the 1 2 or 3 ?
The 2 may be the good suspect with is 8 pin, but i'm not quit sure :uncomfortableness:
