- Mar 4, 2016
- 5
- 0
I have on order an HIKVision DS-7604NI-E1/4P (4 port POE unit). I realize I could have gotten an 8 or more port unit for future expansion but I really think I will only need 2 ports for a long while (I know, many have succumbed to more cameras...).
Here is how I plan to set my network up. I have made a diagram to make this easier, but here are the components, and sample IP addresses to illustrate. My network at home uses a 192.168.1.x address range, and I'll presume that the NVR will have an address range for its own camera network like 10.16.1.x.
I plan to connect the NVR to the router via Ethernet, and a wired camera for the front of the house via the NVR's POE. I need a wireless camera to the back of the house (there's no way to string Ethernet across the house to the NVR). It will be connected via WiFi to the router for the home network.
Can the NVR be set to use cameras that are attached to the home network (not just the NVR's own Ethernet ports)? It would be awesome if it could address any number of local network cameras in addition to the 4 hardware ports on the unit itself, but if I understand what I've read, I think you have to map other cameras to one of the internal NVR "ports" thus a 7604 will have only a total 4 possible cameras attached (including wired to the POE ports of the unit plus any local network attached IP cameras). Is this correct?
Thus, my main questions are:
1. Will the NVR bridge the 2 networks to utilize the camera(s) attached directly to the NVR's POE ports plus local network (192.168.1.x) connected IP camera(s)?
2. Am I limited to only 4 total cameras (local NVR and home network attached cameras) with this unit (again, I'm OK with that for my projected use, just wondering about future addictions...)?
Thanks, and sorry for the newbie questions.
