DHI NVR4232 PASSWORD RESET
khatrizee
Sep 25, 2024
1
Karachi Pakistan
Hi, I bought used NVR4232. All legal, have invoice, etc. However the previous owner didn't reset device to factory settings. I have no possibility
to reset it using email account.
And now comes the problem, device has no reset button.
Do you know maybe how I can reset it without sending it for repairing? Is there any jumper I can use? Was trying to find some information, but it was said something about J1 jumper which is not at the motherboard
You may be able to use a wire across the reset button location.
Please tell me you spend a maximum of $5 on this.... there is so much moisture corrosion I see on the circuit board.
I have an NVR with this reset button location but soldering a reset button in place did not work. I went to my Dahua office to get it reset (costs a fee).
