Decompiling Hikvision firmware (9000 series) digicap.mav
korin1
Aug 27, 2017
45
8
hey there,
im trying to decompile /extracting an hikvision firmware 9k series. (ds-90xx96xx-st77xx-sp_usa_firmware_v3.4.5_170518.zip)
a digicap.mav file, is there anyone has successes extracting it properly ?
so far i was able to extract the firmware BUT some files are still encrypted
extracted files ,
diskOK.bmp: PC bitmap, Windows 3.x format, 48 x 48 x 24
disknoLink.bmp: PC bitmap, Windows 3.x format, 48 x 48 x 24
ds_80101.bit: data
guirc.tar.gz: data
initrun.sh: data
logo.bmp: PC bitmap, Windows 3.x format, 1024 x 768 x 24
logo_nvr.bmp: PC bitmap, Windows 3.x format, 1024 x 768 x 24
mux_top.bit: Xilinx BIT data - from mux_top.ncd;HW_TIMEOUT=FALSE;UserID=0xFFFFFFFF - for 6slx25fgg484 - built 2011/08/15(10:31:38) - data length 0xc3ab6
new_10.bin: data
rootfs.img: gzip compressed data, was "initrd", last modified: Fri May 29 07:29:28 2015, max compression, from Unix
uImage: u-boot legacy uImage, Linux-2.6.34, Linux/ARM, OS Kernel Image (Not compressed), 2626248 bytes, Sat Jan 16 08:20:22 2016, Load Address: 0x80008000, Entry Point: 0x80008000, Header CRC: 0xE53DE128, Data CRC: 0x2415E5FB
vps_logo.bin: data
webs.tar.gz: data
_________________________________________________________________________
-rwxrwxrwx 1 root root 6.9K Aug 2 00:08 diskOK.bmp
-rwxrwxrwx 1 root root 6.9K Aug 2 00:08 disknoLink.bmp
-rwxrwxrwx 1 root root 2.8M Aug 2 00:08 ds_80101.bit
-rwxrwxrwx 1 root root 16M Aug 2 00:08 guirc.tar.gz
-rwxrwxrwx 1 root root 2.3K Aug 2 00:08 initrun.sh
-rwxrwxrwx 1 root root 2.3M Aug 2 00:08 logo.bmp
-rwxrwxrwx 1 root root 2.3M Aug 2 00:08 logo_nvr.bmp
-rwxrwxrwx 1 root root 783K Aug 2 00:08 mux_top.bit
-rwxrwxrwx 1 root root 1.1K Aug 2 00:08 new_10.bin
-rwxrwxrwx 1 root root 1.2M Aug 2 00:08 rootfs.img
-rwxrwxrwx 1 root root 2.6M Aug 2 00:08 uImage
-rwxrwxrwx 1 root root 91K Aug 2 00:08 vps_logo.bin
-rwxrwxrwx 1 root root 3.8M Aug 2 00:08 webs.tar.gz
note that webs.tar.gz AND guirc.tar.gz should be gzip file however those are encrypted.
even initrun.sh who should be normal text is encrypted.
help would be nice.
thanks
I just tried this with @montecrypto hikpack tool and it looks OK.
[MCR] Hikvision packer/unpacker for 5.3.x and newer firmware
Code:
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ hikpack_2.5
hikpack v2.5 Hikvision firmware packer/unpacker by montecrypto
*** No expressed or implied warranties of any kind. Use at your own risk ***
Usage:
   hikpack -t <fwtype> -i <src_dav_file>                     print dav file information
   hikpack -t <fwtype> -x <src_dav_file> -o <dst_dir>        extract dav file into directory
   hikpack [opts] -t <fwtype> -p <dst_dav_file> -o <src_dir> pack dav file from source directory
   hikpack -t <fwtype> -d <src_crypted_file> -o <dst_file>   decrypt file
   hikpack -t <fwtype> -g <src_crypted_cfg> -o <dst_file>    decrypt configuration backup file
   hikpack -t <fwtype> -G <src_file> -o <crypted_cfg_file>   encrypt configuration backup file (CRC adjusted if needed)
   hikpack -t <fwtype> -e <src_file> -o <dst_crypted_file>   encrypt file
     -t option sets firmware platform type. Currently supported: cameras: r0,r1,r6,g0 nvr: k41,k51
     ----- The following options are used by the pack (-p) command:
     -L <1,2>      set language id (1=EN, 2=CN)
     -D <YYYYMMDD> set firmware date.
     -V <ver>      set firmware version. Use hex number, e.g.: 0x05040003 for v5.4.3
If you find this software useful, please donate to support future development:
    Bitcoin: 1N9fKwsy7AphUHZJshCp4L7RJG5CvuXnAk
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ hikpack_2.5 -t k41 -i digicap.mav
Magic   : 484b5753
hdr_crc : 00007723 (OK)
lang_id : 00000001
date_hex: 20150315
devclass: 00000009
File: uImage, CRC OK
File: rootfs.img, CRC OK
File: initrun.sh, CRC OK
File: guirc.tar.gz, CRC OK
File: webs.tar.gz, CRC OK
File: disknoLink.bmp, CRC OK
File: diskOK.bmp, CRC OK
File: logo.bmp, CRC OK
File: logo_nvr.bmp, CRC OK
File: vps_logo.bin, CRC OK
File: mux_top.bit, CRC OK
File: ds_80101.bit, CRC OK
File: new_10.bin, CRC OK
=== Tail record:
File: new_20.bin, CRC OK
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ hikpack_2.5 -t k41 -x digicap.mav -o contents
Magic   : 484b5753
lang_id : 00000001
date_hex: 20150315
devclass: 00000009
=== Tail record:
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ cd contents
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5/contents $ hikpack_2.5 -t k41 -d initrun.sh -o dec_initrun.sh
Example decrypt :
Code:
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5/contents $ cat dec_initrun.sh
cd /home/hik
/bin/tar -zxf dvrCmd.tar.gz -C /opt/
#/bin/cp /dav0/vid_m3.bin /home/hik
#/bin/cp /dav0/vps_m3.bin /home/hik
#/bin/cp /dav0/C674.bin /home/hik
# echo mount -t nfs -o nolock 10.1.14.117:/back-end-team/linyanhao/data/nfs/ /tmp/
# mount -t nfs -o nolock 10.1.14.117:/back-end-team/linyanhao/data/nfs/ /tmp/
# sleep 10
# sleep 10
# #cp /tmp/netra/initrun.sh /dav0/initrun.sh
# cp /tmp/netra/C674.bin /home/hik
# cp /tmp/netra/vps_m3.bin /home/hik
# cp /tmp/netra/vid_m3.bin /home/hik
#rm dvrCmd.tar.gz -f
LD_LIBRARY_PATH=/home/app/lib/;export LD_LIBRARY_PATH
/bin/chmod u+x ./iscsi/iscsid
./iscsi/iscsid&
/bin/chmod u+x ./pppoed
#./pppoed&
sleep 1
insmod cmemdrv.ko
#rm cmemdrv.ko -rf
ulimit -n 8192
/bin/chmod u+x ./ -R
# #disable psh
# sed -i '/psh/d' /etc/profile
# sed -i '/guest/d' /etc/profile
# #genrate core
# echo  "/tmp/core%t" >/proc/sys/kernel/core_pattern
# ulimit -c unlimited
# echo  mount mount moutn111
# mount -t nfs 10.1.14.117:/back-end-team/liwei/data/nfs/v3.2.0 /tmp -o nolock,proto=tcp,nfsvers=3;
# echo  mount mount moutn222
# sleep 10
# echo  mount mount moutn333
# sleep 10
# cp -f /tmp/master /home/app/exec/;
# cp -f /tmp/sc_hicore /home/hik/ ;
# cp -f /tmp/1024x768.cfg /home/app/conf/1024x768.cfg;
# cp -f /tmp/720x576.cfg /home/app/conf/720x576.cfg;
# cp -f /tmp/string /home/app/string/
./master -M &
#rm master -rf
cd /
#wl added
/bin/chown -R root:root /opt/dvrCmd
/bin/chown -R root:root /opt/webs
/bin/chmod a+s /bin/su
/bin/chmod a+s /opt/dvrCmd/dvrtools
/bin/chmod -R 744 /dav0
/bin/chmod -R 744 /dav1
/bin/chmod -R 744 /dav2
/bin/chmod 777 /dev/hikio
/bin/chmod 777 /dev/ttyS1
/bin/chmod 777 /dev/ttyS2
/bin/chmod 777 /dev/rtc
#for T1 test
/bin/chmod 777 /opt/dvrCmd/t1
/bin/chmod a+s /opt/dvrCmd/t1
#wl added end
Code:
Usage:
Magic   : 484b5753
lang_id : 00000001
date_hex: 20150315
devclass: 00000009
=== Tail record:
Magic   : 484b5753
lang_id : 00000001
date_hex: 20150315
devclass: 00000009
=== Tail record:
Example decrypt :
Code:
cd /home/hik
# sleep 10
# sleep 10
./iscsi/iscsid&
#./pppoed&
sleep 1
insmod cmemdrv.ko
#rm cmemdrv.ko -rf
ulimit -n 8192
# #disable psh
# #genrate core
# sleep 10
# sleep 10
./master -M &
#rm master -rf
cd /
#wl added
#for T1 test
#wl added end
have u tried on this https://us.hikvision.com/sites/defa...96xx-st77xx-sp_usa_firmware_v3.4.5_170518.zip ?
can u please reupload the hik tool it seems rghost is down for the moment
Yes, that's the firmware I tested hikpack on.
Attached here.
thanks for the upload
well thats weird
extraction seems to work fine , but i got the same result when extracking with the hipack.
files are still encrypted.
at first i thought something was wrong.
after reading again ur commands it seems that after the extraction of the mav file, u gota decrypt the encrypted files aswell :)
thanks.
do u have a source code of that / python code for decrypting only the file?
here for example it is the same code but when trying to decrypt a file it did not work.
UPDATE:
for everyone that tries to unpack/untar the web and guirc gzip file, u will receive an error when trying to open and u wont be able to open the "tar" file inside the gzip file.
however if u extract the tar file from the gzip file (WITH OUT OPENING THE GZIP FILE!) it will work, if u try to extract or open the tar file when the gzip file is open it will FAIL.
i was scratching my head for some time and for some reason it was decrypted but i could not open the tar file inside the gzip file with 7z , untill i right click and extracted, still received that error but the file was there.
No, I don't have any Python code for the file encryption/decryption.
Unpacking the firmware header and files is a different type of activity than decrypting a file.
Those specific NVR files are DES-3 encrypted.
It's actually a tar file using gzip compression.
You may find it easier to use 'tar' itself to do the unpacking of the decrypted archive, with the 'gzip' command line option, for example :
Code:
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ ll
total 61744
drwxrwxr-x  3 alastair alastair     4096 Aug  2 20:38  ./
drwxrwxr-x 47 alastair alastair     4096 Aug  2 11:09  ../
drwxr-xr-x  2 alastair alastair     4096 Aug  2 20:31  contents/
-rw-r--r--  1 alastair alastair     2264 Aug  2 11:11  dec_initrun.sh
-rw-rw-r--  1 alastair alastair 33007352 May 18  2017  digicap.mav
-rw-rw-r--  1 alastair alastair 26176553 Aug  2 11:09  ds-90xx96xx-st77xx-sp_usa_firmware_v3.4.5_170518_0.zip
-rw-rw-r--  1 alastair alastair    81530 Jul 12  2017 'RN DS-90xx-ST DS-96xx-ST DS-7716NI-SP^16 v3.4.5 071117NA.pdf'
-rw-r--r--  1 alastair alastair  3940216 Aug  2 11:10  webs.tar.gz
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ hikpack_2.5 -t k41 -d webs.tar.gz -o dec_webs.tar.gz
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ mkdir home
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ tar -zxf dec_webs.tar.gz -C home
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ ll home
total 12
drwxr-xr-x 3 alastair alastair 4096 Aug  2 20:39 ./
drwxrwxr-x 4 alastair alastair 4096 Aug  2 20:39 ../
drwxr-xr-x 5 alastair alastair 4096 May 18  2017 webs/
alastair@PC-I5 ~/cctv/NVRFirmware/3.4.5 $ ll home/webs
total 32
drwxr-xr-x 5 alastair alastair 4096 May 18  2017 ./
drwxr-xr-x 3 alastair alastair 4096 Aug  2 20:39 ../
drwxr-xr-x 2 alastair alastair 4096 Mar  2  2017 codebase/
-rwxr--r-- 1 alastair alastair  778 Mar  2  2017 dispatch.asp*
drwxr-xr-x 6 alastair alastair 4096 Mar  2  2017 doc/
-rwxr--r-- 1 alastair alastair 1150 Mar  2  2017 favicon.ico*
drwxr-xr-x 5 alastair alastair 4096 May 18  2017 help/
-rwxr--r-- 1 alastair alastair  480 Mar  2  2017 index.asp*
Reactions: Purduephotog
i forgot to mention that it was on windows :)
where the 3DES key can be found ?
Disclosure - from the DES_ecb3 source code freely provided by another forum member :
Code:
    const DES_cblock key1 = {0x24, 0x8B, 0xA7, 0xF5, 0x4C, 0x7B, 0x9A, 0xE3},
                     key2 = {0x98, 0x75, 0x14, 0xE1, 0x1C, 0xBC, 0x46, 0xE3},
                     key3 = {0x78, 0x41, 0xBC, 0x11, 0x00, 0xB9, 0x2C, 0x13};
    DES_key_schedule ks1, ks2, ks3;
No - but this command-line should work OK, if you ignore the 'bad decrypt' diagnostic :
Code:
This works OK, though gives a bad decrypt, not sure why.
openssl enc -d -in encFile -out decFile -des-ede3 -K 248BA7F54C7B9AE3987514E11CBC46E37841BC1100B92C13
Attached here.
@alastairstevenson - I tried following line by line your example there, and I finally get it to work. Thank you.
When I tried to pull apart my firmware for my NVR (the problematic one) I'll get:
Code:
openwrt@openwrt-VirtualBox:~/firmware/EZVIZNVR$ ../hikpack-2.5 -t k41 -i digicap.dav
Magic   : 484b5753
hdr_crc : 000018d3 (OK)
lang_id : 00000001
date_hex: 20160606
devclass: 0000002a
File: cramfs.img, CRC OK
=== Tail record:
Extra tail at the end of dav, 71 bytes, maybe firmware id?
I think I just realized there's a difference between hikpack and hik_repack v9/10 etc.... I'm slow
Hello, I have the NVR which i install an update with a firmware i_series_usa_firmware_v3.4.92_170518 that has a file digicap.dav, causing the NVR no longer pass the logo screen, beeping 15 times and then restarting. I found another page with the firmware ds-90xx96xx-st77xx-sp_usa_firmware_v3.4.2_160530, which has a file digicap.mav and I tried to install it using the Putty console and TFTP Sever, but the TFTP does not recognize the extension .MAV, how can I install the correct firmware?
The first firmware upgrade i download from https://www.hikvision.com/en/Support/Downloads/Firmware/NVR (digicamp.dav), after the instalation the NVR no longer pass the logo screen.
The page with the correct firmware for my NVR is digicap.mav is https://us.hikvision.com/en/products/more-products/discontinued-products/network-video-recorder/ds-7700ni-sp-series-nvr-ds-7716ni-sp16
