Hi
Does anyone know why i cant upgrade the firmware on my dahua sd22204t-gn
to V2.640.0000000.2
ive tried numerous times on windows 7 and windows 10 on config tool and IE
I did read up and try to change the TCP prt to 3800 but got the " port has been occupieed"
any helps is appreciated and i will update if i get it solved
adam
to V2.640.0000000.2
adam
 thanks for that, dont know the place where i can get that firmware?
