- Apr 23, 2018
- 201
- 69
Quick question about NVR hard drive installation.  I have a Dahua NVR5216-4KS2 NVR that is my home office. The NVR was a little loud that even my old ears can hear.  I decided replace the OEM fan with a  Noctua Premium fan.  This helped a bunch.  There still is some hard drive noise from the rotating hard drives.  I observed that the NVR metal incasement is amplifying the noise from the spinning hard drives.
My question is can I install a thin rubber flat washer on the hard drive mounting screws to help dampen the spinning noise some? Not sure if the hard drive has to be grounded to the case with these screws. Also not sure about heat dissipation by having the screws insulated from case. Not even sure if this may help. I have WD 10TB Purple hard drives (WD101PURZ).
Thank you
M
Thank you
M
