I have installed microSD cards in all 4 of my cameras, and trying to get ANR (Automatic Network Replenishment) functioning. According to the spec sheet for this NVR, this is the feature description:
ANR (Automatic Network Replenishment Technology)
Video record in SD card in IP cameras when the network breaks down, and after the network recovered, the video will be transferred to NVR and then recorded in it.
You need to check the ANR setting for each cam on the NVR. There is also a Redundancy option available, but it is not possible to check it.
My question is, does anyone have this feature functioning correctly? And if so, what did you do to get it working?
