- Apr 21, 2016
- 37
- 5
Hi,
I just received my 4208-8p-4K NVR and IPC-HDW4431C-A, so everything from Dahua.
Everything works great and I'm now playing with fine tuning. Regarding the settings of the image quality, do I need to remotely connect to the IP cam or everything is available through the NVR HMI ?
If yes, how to connect to this cam? 4431C-A is connected to the POE NVR LAN (so not directly the LAN). My NVR is connected to the LAN but I guess I'd have to configure some routing somewhere...
Regards.
Regards.
