Hi,
I have some problems with setting up my Dahua NVR with my 4 Dahua IP cameras.
Each time I use the Remote Search function, the NVR auto adds all my cameras (sometimes it even adds the same camera multiple times). It seems like it tries to login to each of the cameras using admin/admin, but when i initialize the cameras, I was forced to change the password, using at least 8 characters. To avoid the NVR from locking the admin account, I have created a new account (called nvr) on each of the cameras.
When I change the username and password on any of the auto added cameras, it seems to work okay, but when i refresh or go to the live view, the NVR have reset the username and password to the admin account.
The same thing happens if I add the cameras manually.
I have tried to use the SmartPSS software from Dahua, to control the NVR. Here I'm able to add the cameras manually, using the "nvr" account and live view them - they all work perfectly. But when i reboot the NVR (either using the Maintenance feature or by removing the power cord) it forgets the logins and reverts back to the admin account.
Please see this video where I have added all four cameras manually, using the SmartPSS software. They are setup using the "nvr" account on each camera and they are all displaying the video feed, but when I reboot the NVR, they reset back to "admin" account:
Have anyone had the same problems and how did you solve them? Is the NVR broken?
Thank you very much.
Some more info:
I have the following:
The 4 cameras are connected to the NVR using CAT6 cables and are powered by PoE from the NVR.
The NVR switch is setup to use the 10.1.1.xxx subnet and the NVR is attached to my router, which is in the 192.168.1.xxx subnet.
Each camera has been assigned a static IP (10.1.1.66-69).
Some more info:
- 1x Dahua NVR (DHI-NVR4104-P)
- 4x Dahua IPC - HDW4431EM-ASE
