hiya, first time poster but semi long time lurker.
I had a jobsite yesterday where I needed to add an older Dahua DVR to the 192.168.1.xxx network to integrate it with an OpenEye, as it's currently on the 192.168.0.xxx network from before the customer's ISP swap.
I noticed that no matter what I did, I could not change the IP of this box. I couldn't edit anything besides DNS, and even with it being stuck on DHCP I couldn't get it to adapt to the new network. Restarted box multiple times.
I attempted to directly connect my laptop to the box to interface which works, but I get stuck on "PLEASE INSTALL PLUGINS!" and it keeps whining and yelling about NPAPI plugins being enabled.
I tried to install these plugins 4 times, but every time it would act like it's installing then just die out and nothing would change.
I then tried to install IE 10/11 for compatibility view, couldn't even install this as it appears to no longer be supported. Enabled compatibility view on Edge, no dice. Downgraded my Firefox to v50 for older plugin support and added a boolean string to disable the requirements for this plugin, again no dice.
I then tried to do Smart PSS setup while directly connected to my laptop. I was able to get in and do everything and see everything normally, but again I couldn't edit any IP settings. All grayed out and couldn't edit a single thing.
Does anyone have any input on this? I've never run into this issue before; or not at least one that a reboot couldn't help solve.
