New to the forum. Thanks in advance, everyone!
Dahua NVR5464-4KS2
Using Dahua IPC-HDW4631C-A cams
TP Link managed PoE switches
IVS setup menu on NVR
I set up the cameras using the web browser before connecting to NVR. When I set up a schedule on the NVR for IVS email snapshot, within hours, the schedule is back to the default 24/7 schedule. Other settings such as "buzzer" and even sometimes the object target sizes also go back to default. I've tried to re-enter a new schedule again using both the web browser AND using the NVR itself and most of the cams resort back to full-time 24/7 scheduling. Verified that cams are not losing power.
Another problem is that some of the cameras' sub stream setting keeps changing from H264 back to H265 along with their bit rates. This happens once or twice a day on only several cameras.
It's almost as if there's a conflict between the NVR and the cams. Is there a way to disable the NVR from updating/changing setting on the cams where I can make changes only through the browser using the cam's IP address and the NVR can't change what I did?
Any ideas?
Dahua NVR5464-4KS2
Any ideas?
