With @EMPIRETECANDY 's sale coming up, I'm finally going to add a central NVR to my setup. My problem is knowing which is the latest/best version though to support the AI and other features. I suspect it's the NVR52xx-xx-EI ones, the -El being the important bit. But is the NVR54XX-4kS2 worse or better? The 4KS2 is priced higher, and the 32 channel versions supports 4HDD instead of just 2 on the -EL.
Thanks
JG
Thanks
JG
