G'day everyone,
So I have a 16 channel nvr,
3 cameras are connected directly to the poe switch on the nvr.(No issue there)
I'm using comfast wireless ap's to bridge to other buildings (connected to nvr poe switch)
I had this problem "Failed to find network host" with the 1st connected ap a few months back, it would come up about 10 minutes after you reboot the nvr, before that it would work fine. Somehow I fixed it and it stopped happening, I think I may have modified the ip cams to static ip's.
But I added more cameras recently and found out I had to add another ap to the nvr switch for the extra bandwidth and now I'm having the problem again.
After boot up the newest cameras work for about 10 mins then I get "failed to find network host" while they are working I can ping the ap's from the nvr fine, after they stop I can't ping them.
In the 2nd building there are 4 cameras connected to a poe switch. All on static ip's
Does anyone know why this is? It's doing my head in.
Also the originally added ap is still working fine... no issues with that one.
Thanks heaps.
Thanks heaps.
