I should have mentioned not to install or mess with the PC-NVR component.
SmartPSS is actually two components, the viewer/playback part and a VMS part that uses your PC for storage. The VMS part is not so good. I wouldnt recommend it. But for Live View/Playback/Downloading clips it works great.
I was wondering about PC-NVR, it seems that it just looks for PC storage. If I have my camera added to smart pss and tell my camera to record locally to my 'test' folder, then I don't see why I need PC-NVR. Would I only need PC-NVR if I didn't want an NVR and wanted to use my PC and the PC's storage for recording the cameras? I can exit/uninstall it or just not configure/use it.
I do want to try to export video to see my options, do I need an NVR connected to do that or is there a way to test that within smart pss (as if I had an NVR).
