I'm struggling to get a Seagate Iron Wolf 4Tb HDD to work in a Dahua nvr.
Should I be able to get it to work or do I need to purchase a Skyhawk?
What are the symptoms?I'm struggling to get a Seagate Iron Wolf 4Tb HDD to work in a Dahua nvr.
| All | Device Name | Physical Position | Type | Health status | Free Space |
| 1 | sda | main board-1 | Read/Write | Warning | 0.00MB/0.00MB |
Both would be perfectly good choices and should work OK.I'm a newby at this and I'm concerned that I should have purchased a Sky Hawk rather than an Iron Wolf HDD
No - you need to look at the attribute data, if the NVR has that detail.Below is a photo of the SMART data for this HDD.
| Port | main board-1 |
| Model | ST4000VN008 |
| No. | ZGY88CMC |
| Status | It is malfunction, cannot use |
| Smart ID | Attribute | Threshold Value | Worst Value | Current Value | Status |
| Blank row... | |||||
| Blank row... |
Many thanks. I'm in contact with them now.i think that the first sector being bad is a major problem. Contact the disk manufacture.
