I use a
and would like to use the Multi-Live-Stream (Channel 9)
under Home Assistant over the Onvif Integration. The RTSP stream
can be accessed using the HA Generic camera Integration, or the Dahua Addon from rroller, but not via the Onvif integration. Unfortunately, when you access channel 9 via Onvif, there is no picture/stream.
So the question is whether Multi-Live-Stream via Onvif is even available?
BTW: Why Onvif Integration and not the Dahua Addon? Among other things/problems, the Dahua addon logs into the NVR every second and thus floods the log.
Unfortunately, rroller is no longer developing the addon and unfortunately no longer responds to issues reports.
Code:
rtsp:/User:Password@IP:554/cam/realmonitor?channel=9&subtype=0
Code:
