Hi All,
I've been working on customising commands to control my Dahua NVR from http commands. Ultimately I will add these into a remote interface for control of the DVR.
I've attached the API document I have for NVR/DVRs. This gives commands for most options but I'm struggling to get a command to display a specific Tour screen on the NVR.
I have my NVR connected to an HDMI Matrix to allow viewing of the cameras in any room of the property. I want to be able to switch between screens easily using these commands. I can switch to individual cameras and I can even switch to split screens which display the cameras in order of channel number. However I have setup the Tour option to display two screens of 9 cameras with a delay between. I'm trying to find a command to switch directly to either of these Tour screens.
Page 74 of the attached guide shows how to enable Tour which works fine. I can also freeze the tour on each screen. However If I switch to a specific camera I would like a command to go back to one of the set Tour screens.
Here's my current Tour Configuration:
table.MonitorTour[0].CombinationTour.Split1[0].Combination[0]=0
table.MonitorTour[0].CombinationTour.Split1[0].Enable=true
table.MonitorTour[0].CombinationTour.Split1[1].Combination[0]=1
table.MonitorTour[0].CombinationTour.Split1[1].Enable=true
table.MonitorTour[0].CombinationTour.Split1[2].Combination[0]=2
table.MonitorTour[0].CombinationTour.Split1[2].Enable=true
table.MonitorTour[0].Enable=false
table.MonitorTour[0].Interval=5
table.MonitorTour[1].CombinationTour.Split1[0].Combination[0]=0
table.MonitorTour[1].CombinationTour.Split1[0].Enable=0
table.MonitorTour[1].CombinationTour.Split1[1].Combination[0]=1
table.MonitorTour[1].CombinationTour.Split1[1].Enable=0
table.MonitorTour[1].CombinationTour.Split1[2].Combination[0]=2
table.MonitorTour[1].CombinationTour.Split1[2].Enable=0
table.MonitorTour[1].CombinationTour.Split1[3].Combination[0]=3
table.MonitorTour[1].CombinationTour.Split1[3].Enable=0
table.MonitorTour[1].CombinationTour.Split1[4].Combination[0]=4
table.MonitorTour[1].CombinationTour.Split1[4].Enable=0
table.MonitorTour[1].CombinationTour.Split1[5].Combination[0]=5
table.MonitorTour[1].CombinationTour.Split1[5].Enable=0
table.MonitorTour[1].CombinationTour.Split1[6].Combination[0]=6
table.MonitorTour[1].CombinationTour.Split1[6].Enable=0
table.MonitorTour[1].CombinationTour.Split1[7].Combination[0]=7
table.MonitorTour[1].CombinationTour.Split1[7].Enable=0
table.MonitorTour[1].CombinationTour.Split1[8].Combination[0]=8
table.MonitorTour[1].CombinationTour.Split1[8].Enable=0
table.MonitorTour[1].CombinationTour.Split1[9].Combination[0]=9
table.MonitorTour[1].CombinationTour.Split1[9].Enable=0
table.MonitorTour[1].CombinationTour.Split1[10].Combination[0]=10
table.MonitorTour[1].CombinationTour.Split1[10].Enable=0
table.MonitorTour[1].CombinationTour.Split1[11].Combination[0]=11
table.MonitorTour[1].CombinationTour.Split1[11].Enable=0
table.MonitorTour[1].CombinationTour.Split1[12].Combination[0]=12
table.MonitorTour[1].CombinationTour.Split1[12].Enable=0
table.MonitorTour[1].CombinationTour.Split1[13].Combination[0]=13
table.MonitorTour[1].CombinationTour.Split1[13].Enable=0
table.MonitorTour[1].CombinationTour.Split1[14].Combination[0]=14
table.MonitorTour[1].CombinationTour.Split1[14].Enable=0
table.MonitorTour[1].CombinationTour.Split1[15].Combination[0]=15
table.MonitorTour[1].CombinationTour.Split1[15].Enable=0
table.MonitorTour[1].CombinationTour.Split9[0].Combination[0]=6
table.MonitorTour[1].CombinationTour.Split9[0].Combination[1]=16
table.MonitorTour[1].CombinationTour.Split9[0].Combination[2]=0
table.MonitorTour[1].CombinationTour.Split9[0].Combination[3]=3
table.MonitorTour[1].CombinationTour.Split9[0].Combination[4]=7
table.MonitorTour[1].CombinationTour.Split9[0].Combination[5]=2
table.MonitorTour[1].CombinationTour.Split9[0].Combination[6]=15
table.MonitorTour[1].CombinationTour.Split9[0].Combination[7]=14
table.MonitorTour[1].CombinationTour.Split9[0].Combination[8]=5
table.MonitorTour[1].CombinationTour.Split9[0].Enable=1
table.MonitorTour[1].CombinationTour.Split9[1].Combination[0]=4
table.MonitorTour[1].CombinationTour.Split9[1].Combination[1]=8
table.MonitorTour[1].CombinationTour.Split9[1].Combination[2]=9
table.MonitorTour[1].CombinationTour.Split9[1].Combination[3]=10
table.MonitorTour[1].CombinationTour.Split9[1].Combination[4]=11
table.MonitorTour[1].CombinationTour.Split9[1].Combination[5]=12
table.MonitorTour[1].CombinationTour.Split9[1].Combination[6]=13
table.MonitorTour[1].CombinationTour.Split9[1].Combination[7]=16
table.MonitorTour[1].CombinationTour.Split9[1].Combination[8]=14
table.MonitorTour[1].CombinationTour.Split9[1].Enable=1
table.MonitorTour[1].Enable=true
table.MonitorTour[1].Interval=5
I want to be able to display CombinationTour.Split9[0] and CombinationTour.Split9[1] using an http request.
Can anyone help?
Can anyone help?
