- May 18, 2014
- 46
- 4
I have this NVR set up to record always and also have motion control on so it will show yellow on the search bar where there's motion, but if you search anywhere outside the motion blocks, it jumps ahead or back to the closest hour. You can't play any of the green area showing what's been recorded on the search bar directly. If you let it play, it will play through the green, you just can't get to a specific part directly.
Any idea what might be going on?
