Dahua NVR 4104 - Able to set number of days for recording
psycik
Dec 9, 2015
230
43
Wellington, New Zealand
Every so often I hear a couple of beeps from my NVR or get the email to say it's run out of space. It has a 2Tb drive in it.
I have 4 cameras running. Is there any way of setting how many days I can keep? or do I just let it run out and self correct?
disable disk full alarm notifications and configure it to over-write..
there is but thats an entirely different setup, you have to run fixed bitrates and do the math on your own.. the alarm is to let you know your math was wrong..
for an overwrite setup; which is by far the most common, disable that alarm and it should disable both the beep and the email alert.
