LittleScoobyMaster Getting the hang of it Jul 24, 2015 229 24 Jul 19, 2017 #1 NK8BA4 Does this 12MP / 4K camera compare to the 5231 models as far as low light is concerned? Curious what the sensor is for this one. It lists .001 lux on the site but I understand those are not always accurate. Last edited: Jul 19, 2017
bp2008 Staff member IPCT+ Member Mar 10, 2014 13,115 14,911 USA Jul 19, 2017 #2 This looks like the same camera: IPC-HF81230E | Dahua Technology - Dahua Technology And here is the 5231 turret: IPC-HDW5231R-Z | Dahua Technology - Dahua Technology Based on that it should be comparable, although the 2MP is rated with an F1.4 lens while the 12MP is rated with a larger F1.2 lens. This is the 12mp bullet with presumably the same sensor. Smaller lens at only F1.53 showing worse low light spec. IPC-HFW81230E-Z | Dahua Technology - Dahua Technology
bp2008 Staff member IPCT+ Member Mar 10, 2014 13,115 14,911 USA Jul 19, 2017 #3 For a box cam with the priority being low light, this is probably a better option: IPC-HF8232F | Dahua Technology - Dahua Technology
LittleScoobyMaster Getting the hang of it Jul 24, 2015 229 24 Aug 7, 2017 #4 bp2008 said: This looks like the same camera: IPC-HF81230E | Dahua Technology - Dahua Technology Based on that it should be comparable, although the 2MP is rated with an F1.4 lens while the 12MP is rated with a larger F1.2 lens. This is the 12mp bullet with presumably the same sensor. Smaller lens at only F1.53 showing worse low light spec. IPC-HFW81230E-Z | Dahua Technology - Dahua Technology Click to expand... The NK8BA4 seems like it has lower lux for BW. I keep hoping these 4k cameras will get decent low light eventually. Dunno if it will ever happen though.
LittleScoobyMaster Getting the hang of it Jul 24, 2015 229 24 Aug 29, 2017 #5 Anyone know which IMX sensor the NK8BA4 contains?
