- Mar 9, 2014
- 36,891
- 21,416
they have no rating for water resistance..but if kept out of direct rain should be fine...there are two new modelsSorry for ressurecting this thread
I was just wondering if anyone knows if this microphone is for internal or external use?
Thanks
These are not network or poe mics..they need to be connected to a camera or nvr's audio input.For POE cameras that are audio enabled, do you have to run a separate line for audio or does it come over cat6 as well?
Right now we sold some PFM141 and tested by my clients in Australia he said the function not bad. This kind of item is good for those who need better voice pick-up.These are not network or poe mics..they need to be connected to a camera or nvr's audio input.
the audio will be part of the video stream...OK - once I connect it to a POE camera's audio input, do I need to run a separate audio line back to the NVR/BI box or does audio come across Cat6 as well?
It would depend on the NVR...I havent used a standalone nvr in years and never connected audio directly to any...If you connect the mic to the NVR would the sound recordings playback whenever you watch any stream (any cameras recording)
And if you connect the mic directly to a camera would the sound recordings be associated with the footage from that camera only?
Thanks
If connected to the nvr audio in,it sets the sound over all cameras,I use separate microphones so each camera has its own audio stream that's assuming your camera has audio input if you have only lets say turret cameras with no audio input then running a mic back to the nvr will pick up that area make sure you run a good power supply and get your grounding rightIf you connect the mic to the NVR would the sound recordings playback whenever you watch any stream (any cameras recording)
Thanks
