I'm having issues with my IP cams changing IPs if they loose power or the NVR is shutdown and turned back on.
I have 7 cameras on a NVR5216-16P-4KS2E. 5 of the cameras are connected via a switch that is directly plugged into a port on the back of the NVR. 2 of the cameras are connected directly into the NVR. I went through set static IPs on all my cameras and assigned channels 1-7. Diagram Attached.
After a shutdown or restart on the NVR few of the cameras have changed IPs. and one has moved to a different channel.
What am I doing wrong on config?
Thanks
Thanks
