Dahua Hdd S.M.A.R.T info
Henry3499
Feb 17, 2019
6
Nigeria
Please how do I identify a faulty hdd.sometimes the smart info show "error","slight","worse" and "ok" but I observe that some hdd that shows "ok" are bad.please can someone teach me how to identify faulty hdd through S.M.A.R.T info.
I would not trust the internal "Dahua" error log but would use is as a starting point. If you really want to find out if you have a failing drive you need to pull it out and bench test it on another computer using the Western Digital Data Lifeguard software. ----> Software and Firmware Downloads | WD Support
To me the reallocated sectors and if it rises/increases over time would be an indication that the disk is on the way out. So in your screenshot the count is at 140, monitor it and the read error rate to see if they are increasing.
As pointed out above, smart gives an indication but I’ve always found that you will get earlier signs so pull the disk out onto a bench and test it with the manufacturers util to see what it makes of the state of the disk.
