Hi.
I have encountered the same issue.
Emailing worked fine with my existing gmail account and after disconnecting and turning off the Dahua DVR unit from my direct connected monitor, to relocate the unit to its final location, the email functionality failed to work.
Having read through all the suggestions in this forum without any success (thanks for these), I decided to open an email account with my broadband supplier. I then configured the Dahua DVR as per the guidelines - and it worked!!
Well I had thought it worked - as the email test was successful. However when checking my email account I found emails advising delivery failures. This was the reason:
Reason: The following message to [email protected] was undeliverable. The reason for the problem: 550-5.7.1 [62.24.135.68 14] Messages missing a valid address in From:
It would appear that the Dahua unit does not use the "Sender" details in the "From" address field. Possibly used in the "ReplyTo" address only. This may be the primary reason why other email servers such as gmail are rejecting the emails - but today was the first time i had any indication of what the underlying issue may have been.
Since sending around 10 "successful" tests from Dahua (each undeliverable) this test facility then started to fail once more. (Sigh)
I firmly suspect an issue with the Dahua DVR, as I have tried multiple accounts and SMTP hosts without any success since I powered the unit down. The software indicates it is on the latest version (System Version: 3.216.0000000.0 Build Date: 2018-06-05), so I don't know where to go from here apart from dumping the Dahua DVR and looking for another brand. I know my gmail account work fine as I receive daily emails from each of my PCs/devices when they are powered up - so no router firewall issues that I am aware of.
Any further suggestions or thoughts on this topic would be appreciated.
Many Thanks
Chas
