Hi, I have a Dahua dvr model XVR4232AN and a few weeks ago the network started to randomly fail.
Now it won't connect to internet at all.
The problem seems to be with the lan port, as both lights are stucked and always on even if the cable is unplugged.
My retailer wont fix it and suggested to buy a new DVR
So... I tried to update the firmware but only have 1 usb port, and I can't connect both the mouse and a pendrive.
Is there a way to update the firmware without network?
And if it is a hardware problem, Is there a way to repair the network card?
thank you for your support.
cheers.
cheers.
