Dahua DHI-NVR5464-4KS2 load balance
Miacomo
Oct 9, 2022
24
7
Pennsylvania
I'm trying to use the two NIC ports as load balancing input for 46 cameras. There are 2 switches with the cameras split up 60/40 on them.
I have Network Mode set as "load balance" and the NIC MEMBER has NIC2 and NIC1 checked.
I can only get one port at a time working. If I plug one of either switch into either NIC port, the one bank works. Swap the 2 switches or NIC ports and it works.
If I connect to both NIC ports, only one bank will work.
Am I missing something here?
Reactions: Flintstone61
