Hi, I joined this forum a while back because I wanted to learn as much as I can about installing a home surveillance system. After weeks of reading virtually every post in this forum I decided to go for dahua cameras.
Winding the clock back a little I looked at this about nine months ago and decided to go for a cheap dummy run to see if it was worth installing a more expensive system. I purchased a Securicam Stalwart - 4 Channel IP 1080p p2p HDMI NVR with a WD 2TB Purple surveillance hard drive and a cheap 1mb Sricam to try. All worked well except for the quality which was naff. I also tried an evaluation version of blue iris and was very impressed by this software.
Fast forward to now, I used AliExpress to purchase a Dahua 4MP IPC-HDW4431C-A POE camera. This arrived within 13 days to the UK.
The new dahua camera appears to work flawlessly with the blue iris software, I can also get into this camera via a web page.
The problem lies when I try to connect this dahua camera to my NVR. I changed the default IP address of the camera to my LAN setup. and also changed the camera resolution to 720P to match my other (cheap) camera but when I attach it to my NVR, the NVR recognizes it but will not connect throwing out a “username error”.
I then tried to check the camera with ONVIF Device Manager v2.2.250, the Device Manager again sees the camera but gives a “Sender not Authorized” warning, is this normal with this camera and are these two issues linked?.
So two issues I need to understand initially, is this dahua compatable with my NVR?
And secondly is this the usual response with the ONVIF Device Manager?, the cheap sricam is picked up no bother.
I eventually will be purchasing three more dahua cameras and a dahua NVR after xmas.
Thanks for your time.
