Hi
I have 5 dahua
type cams, which all worked fine until one didn't give a live feed anymore. I did get this sometimes with other cams so just resetting my switch or nvr worked. However this time it still wouldn't come back online. I tried searching it using nmap, I found the 4 other cams but cam 5 was nowhere to be seen. This was strange to me because the cam gave light and such so it appeared to have POE. As a means of last resort I unscrewed the cam and pressed the reset button, the reset was succesful as the green light went out and it reseted. However the cam still isn't online / reachable via nmap. All cams had static ips but this shouldn't matter as the cam is now reset and should heve factory ip adress.
What should I do now ?
Thx 4 reading
I have 5 dahua
| IPC-HDBW4300E-AS |
Thx 4 reading
