Solar Deity
Getting comfortable
@SirAce135 Sure you are. You running a casino over there, next to that fire pit insert? A gate would be cheaper.I am seriously considering the SD6AL830V-HNI
Was recently robbed of my firepit insert (the one in my photo) and am putting up 20 cams around the house and one at the mouth of the only street allowing access into our neighborhood (still my property). I am really interested in the SVI and catching license plates/drivers.
I am also looking at this monster: 7K (30 MP) HD Pro Cameras | Avigilon -
The single Avigilon solution you list above will run you about 10-12K. Their previous 24MP Sony sensor alone is $3k, without any camera around it, again for just the sensor. Add the newest 30 MP, a body and lens around it and you're in specialized commercial situation. That would be the camera, proprietary software and a proprietary NVR with many TB to handle the 30 MP bandwidth at H.264. Add a $1500 SD6AL830V-HNI, and 19+ cameras, equipment, setup, install and support, and you're approaching 25-30K all in, to protect a fire pit insert (get the gate). If you (or your wife) feel safe with 20+ cams, and have the means to spend 30+K on a system that makes you feel that way, and would rival a casino, have at it. Otherwise I call BS, and this is a bit of grandstanding. People with the means to afford such systems and installs don't peruse these forums. They hire professionals to make it happen, don't ask how much it is, nor brag about it.
If I'm wrong, my apologies and best of luck with your system. I'd love to see example footage of either high end camera, or your 20 camera matrix. I put it all on red.....
SD
