Hi,
I've got the new NVR5216-EI NVR with firmware DH_NVR5XXX-EI_MultiLang_V4.000.0000000.1.R.230620.
Connected are 10 older Dahua cams without AI capabilities (HDW2320R-ZS) and 1 HFW5442TP-ASE.
The cams are all added to the recorder as 'Private' (no ONVIF).
Now the problem: I can't get SMD to work with any of the cams. According to the specs it supports 8 channel SMD by recorder.
Even the 5442 with built in AI won't show its SMD recordings, while I can see in the logs of the cam itself that it generates the notifications.
What I've tried:
Yet I get zero SMD recordings when looking in DMSS, by using smart search in the GUI and by using the search fuction.
Any idea on how to resolve?
What I've tried:
- Reset the MD, SMD and alarm disable periods to be on all the time
- Reset the MD region
- Re-add the cams
- Just have 1 channel SMD by recorder enabled (in case the AI bandwidth is exceeded)
- Checked AI-Mode under AI->Parameters->Local->Smart plan
