Dahua 4k Starlight with 1/2 sensor (CVI only for now)
Hi,
I like this 2831 model, whats the current price on it? Seems its a better overall option than the 5231R-ZE?
thanks
Looking at buying some of the new 1/1.8" sensor domes from Andy.
I want the IPC-HFW1831E but in a dome as the reviews are great (I can not see one on the dome version?).
Before I get all excited, is the IPC-HDBW1831R the dome version of IPC-HFW1831E ??
Here (not Andy) Free Shipping Security IP Camera 8MP WDR Waterproof IR Dome Network Camera With POE IP67 IK10 without Logo IPC HDBW1831R-in Surveillance Cameras from Security & Protection on Aliexpress.com | Alibaba Group
and https://www.dahuasecurity.com/products/productDetail/21477
If confirmed it is the same sensor, I'll email Andy to ask if he can get a couple. [email protected]
ok, answer is yes, it's the same sensor in a dome form factor. Andy does not stock it....but I assume could order it especially - but he mentions that it has the usual dome issues (IR flare on dome etc).
They are pretty good. A definite improvement over older 4K models of similar price, but 2MP starlights are still a definite improvement over these in very low light.
Reactions: fenderman
I got myself one of those and they perform really well.
Excuse the mess, house not finished yet, so I have everything imaginable in my garage during the winter.
Only tested it in my garage, these are iphone screenshots using idmss plus and everything set to default.
Zoomed out
zoomed in
Low light color
low light B&W
Iphone 8 pic:iphone.jpg
You call that a mess?!? I wish my garage looked that good!
Sent from my iPhone using Tapatalk Pro
Any update yet as to when a turret version might be available?
Reactions: flynreelow
I have issues with email notifications and I saw that there is a bug in the FW, is there any recent version that fixes this issue? thanks
@CCTVCam
A7s is a fairly old camera announced back in 2014. There is already A7SIII on the market. I wouldn't compare it to any CCTV cam, as its a full frame sensor camera. Its sensor area is 35 times larger than 1/2.5 inch sensor from for example HDW5831R-Z. Also consider that while the sensor in A7s has 4240 x 2832 pixels, it is recording only fullHD video. Downsized video is averaged from the whole sensor area. Thanks to this the noise level is a bit lower. The video material was post processed with Neat Video, which is a widely used noise reduction plugin. Some shots on the beach were shot at ISO80000 and f1.4 lens. For a full frame sensor it is not a big deal to go that high and get decent result. With my 4239T-ASE I would get identical brightness of this scene with 70% gain, which is an equivalent of ISO40000 plus f1.0 lens.
I have to agree, the bitrate is too low for 4K cams from Dahua. A maximum of 10Mbps is not enough to keep up with all the details the camera is delivering. However after turning on smart codec I noticed a significant improvement of the quality. So I highly recommend using smart codec for a 4K cam. The A7s uses 50Mbps codec. My Panasonic FZ1000 uses 100Mbps for 4K video.
Hey, I did you suggestion and turned on smart codec for the 4k camera IPC-HFW2831T-ZS. However, it automatically switches from CBR to VBR..Should I go ahead and switch back to CBR while smart codec is on ? and then set the bitrate to 8000+? sorry for the nuisance.
