Ctronics Dual Lens setup
Killer Kool
Mar 27, 2015
89
2
I am currently struggling with how to set up the Dual lens unit. As far as I can tell, it has 1 IP address associated with it. I can set it to a fixed ID for BI.
I have tried to do the find and inspect
Unit comes up Make: Generic/ONVIF model *RTSP H2.64/etc The Media port is 554 and onvif is 8080
Stream Profiles "mainstream" /11 second /12.
Sometimes I WILL SEE a FIXED LENS and other times the PTZ lens. I will see a "socket closed" . I have added two cameras separately within BLUE Iris...this seems to cause both to crash . I have moved /11 and /12 around, and the image jumps after a few seconds from the fixed lens to the PTZ lens.
I have seen images in Blue Iris where the stream profiles (in forums) say "lens 1" and "lens 2"!?!! Mine doesn't have those options?
Post the screenshot below. This is from a different camera, but it should show the different cameras (called Channels) in the drop down. Select Channel 1 for one camera and Select Channel 2 for the 2nd camera.
Opening 192.168.0.171 port 80...
HTTP Get / request...
Failed with HTTP 404
Opening 192.168.0.171 port 8080...
ONVIF GetSystemDateAndTime
2023-08-19T20:02:11.000Z
Requesting device information...
Manufacturer: IPCAM
Model: C6F0SgZ0N0PmL2
FirmwareVersion: V31.1.1.11.88-20231024
GetCapabilities...
Querying services
Has Imaging services: /onvif/image_service
Has media services: /onvif/media_service
Has RTP_RTSP_TCP, requesting profiles
profile token MainStreamProfileToken
profile name MainStreamProfile
profile source is VideoIPCameraSourceToken
profile token SecondStreamProfileToken
profile name SecondStreamProfile
requesting URI for profile MainStreamProfileToken
RTSP URI: rtsp:/192.168.0.171:554/11
requesting URI for profile SecondStreamProfileToken
RTSP URI: rtsp:/192.168.0.171:554/12
Has Event services: /onvif/event_service
RelayOutputs: 0
InputConnectors: 0
Has PTZ service: /onvif/ptz_service
Preset: Preset001=Preset001
Preset: Preset002=Preset002
Preset: Preset003=Preset003
Preset: Preset004=Preset004
Preset: Preset005=Preset005
Preset: Preset006=Preset006
Preset: Preset007=Preset007
Preset: Preset008=Preset008
Preset: Preset009=Preset009
Preset: Preset010=Preset010
Preset: Preset011=Preset011
Preset: Preset012=Preset012
Preset: Preset013=Preset013
Preset: Preset014=Preset014
Preset: Preset015=Preset015
Preset: Preset016=Preset016
Preset: Preset017=Preset017
Preset: Preset018=Preset018
Preset: Preset019=Preset019
Preset: Preset020=Preset020
Preset: Preset021=Preset021
Preset: Preset022=Preset022
Preset: Preset023=Preset023
Preset: Preset024=Preset024
Preset: Preset025=Preset025
Preset: Preset026=Preset026
Preset: Preset027=Preset027
Preset: Preset028=Preset028
Preset: Preset029=Preset029
Preset: Preset030=Preset030
Preset: Preset031=Preset031
Preset: Preset032=Preset032
Preset: Preset033=Preset033
Preset: Preset034=Preset034
Preset: Preset035=Preset035
Preset: Preset036=Preset036
Preset: Preset037=Preset037
Preset: Preset038=Preset038
Preset: Preset039=Preset039
Preset: Preset040=Preset040
Preset: Preset041=Preset041
Preset: Preset042=Preset042
Preset: Preset043=Preset043
Preset: Preset044=Preset044
Preset: Preset045=Preset045
Preset: Preset046=Preset046
Preset: Preset047=Preset047
Preset: Preset048=Preset048
Preset: Preset049=Preset049
Preset: Preset050=Preset050
Preset: Preset051=Preset051
Preset: Preset052=Preset052
Preset: Preset053=Preset053
Preset: Preset054=Preset054
Preset: Preset055=Preset055
Preset: Preset056=Preset056
Preset: Preset057=Preset057
Preset: Preset058=Preset058
Preset: Preset059=Preset059
Preset: Preset060=Preset060
Preset: Preset061=Preset061
Preset: Preset062=Preset062
Preset: Preset063=Preset063
Preset: Preset064=Preset064
Preset: Preset065=Preset065
Preset: Preset066=Preset066
Preset: Preset067=Preset067
Preset: Preset068=Preset068
Preset: Preset069=Preset069
Preset: Preset070=Preset070
Preset: Preset071=Preset071
Preset: Preset072=Preset072
Preset: Preset073=Preset073
Preset: Preset074=Preset074
Preset: Preset075=Preset075
Preset: Preset076=Preset076
Preset: Preset077=Preset077
Preset: Preset078=Preset078
Preset: Preset079=Preset079
Preset: Preset080=Preset080
Preset: Preset081=Preset081
Preset: Preset082=Preset082
Preset: Preset083=Preset083
Preset: Preset084=Preset084
Preset: Preset085=Preset085
Preset: Preset086=Preset086
Preset: Preset087=Preset087
Preset: Preset088=Preset088
Preset: Preset089=Preset089
Preset: Preset090=Preset090
Preset: Preset091=Preset091
Preset: Preset092=Preset092
Preset: Preset093=Preset093
Preset: Preset094=Preset094
Preset: Preset095=Preset095
Preset: Preset096=Preset096
Preset: Preset097=Preset097
Preset: Preset098=Preset098
Preset: Preset099=Preset099
Preset: Preset100=Preset100
Preset: Preset101=Preset101
Preset: Preset102=Preset102
Preset: Preset103=Preset103
Preset: Preset104=Preset104
Preset: Preset105=Preset105
Preset: Preset106=Preset106
Preset: Preset107=Preset107
Preset: Preset108=Preset108
Preset: Preset109=Preset109
Preset: Preset110=Preset110
Preset: Preset111=Preset111
Preset: Preset112=Preset112
Preset: Preset113=Preset113
Preset: Preset114=Preset114
Preset: Preset115=Preset115
Preset: Preset116=Preset116
Preset: Preset117=Preset117
Preset: Preset118=Preset118
Preset: Preset119=Preset119
Preset: Preset120=Preset120
Preset: Preset121=Preset121
Preset: Preset122=Preset122
Preset: Preset123=Preset123
Preset: Preset124=Preset124
Preset: Preset125=Preset125
Preset: Preset126=Preset126
Preset: Preset127=Preset127
Preset: Preset128=Preset128
Preset: Preset129=Preset129
Preset: Preset130=Preset130
Preset: Preset131=Preset131
Preset: Preset132=Preset132
Preset: Preset133=Preset133
Preset: Preset134=Preset134
Preset: Preset135=Preset135
Preset: Preset136=Preset136
Preset: Preset137=Preset137
Preset: Preset138=Preset138
Preset: Preset139=Preset139
Preset: Preset140=Preset140
Preset: Preset141=Preset141
Preset: Preset142=Preset142
Preset: Preset143=Preset143
Preset: Preset144=Preset144
Preset: Preset145=Preset145
Preset: Preset146=Preset146
Preset: Preset147=Preset147
Preset: Preset148=Preset148
Preset: Preset149=Preset149
Preset: Preset150=Preset150
Preset: Preset151=Preset151
Preset: Preset152=Preset152
Preset: Preset153=Preset153
Preset: Preset154=Preset154
Preset: Preset155=Preset155
Preset: Preset156=Preset156
Preset: Preset157=Preset157
Preset: Preset158=Preset158
Preset: Preset159=Preset159
Preset: Preset160=Preset160
Preset: Preset161=Preset161
Preset: Preset162=Preset162
Preset: Preset163=Preset163
Preset: Preset164=Preset164
Preset: Preset165=Preset165
Preset: Preset166=Preset166
Preset: Preset167=Preset167
Preset: Preset168=Preset168
Preset: Preset169=Preset169
Preset: Preset170=Preset170
Preset: Preset171=Preset171
Preset: Preset172=Preset172
Preset: Preset173=Preset173
Preset: Preset174=Preset174
Preset: Preset175=Preset175
Preset: Preset176=Preset176
Preset: Preset177=Preset177
Preset: Preset178=Preset178
Preset: Preset179=Preset179
Preset: Preset180=Preset180
Preset: Preset181=Preset181
Preset: Preset182=Preset182
Preset: Preset183=Preset183
Preset: Preset184=Preset184
Preset: Preset185=Preset185
Preset: Preset186=Preset186
Preset: Preset187=Preset187
Preset: Preset188=Preset188
Preset: Preset189=Preset189
Preset: Preset190=Preset190
Preset: Preset191=Preset191
Preset: Preset192=Preset192
Preset: Preset193=Preset193
Preset: Preset194=Preset194
Preset: Preset195=Preset195
Preset: Preset196=Preset196
Preset: Preset197=Preset197
Preset: Preset198=Preset198
Preset: Preset199=Preset199
Preset: Preset200=Preset200
Preset: Preset201=Preset201
Preset: Preset202=Preset202
Preset: Preset203=Preset203
Preset: Preset204=Preset204
Preset: Preset205=Preset205
Preset: Preset206=Preset206
Preset: Preset207=Preset207
Preset: Preset208=Preset208
Preset: Preset209=Preset209
Preset: Preset210=Preset210
Preset: Preset211=Preset211
Preset: Preset212=Preset212
Preset: Preset213=Preset213
Preset: Preset214=Preset214
Preset: Preset215=Preset215
Preset: Preset216=Preset216
Preset: Preset217=Preset217
Preset: Preset218=Preset218
Preset: Preset219=Preset219
Preset: Preset220=Preset220
Preset: Preset221=Preset221
Preset: Preset222=Preset222
Preset: Preset223=Preset223
Preset: Preset224=Preset224
Preset: Preset225=Preset225
Preset: Preset226=Preset226
Preset: Preset227=Preset227
Preset: Preset228=Preset228
Preset: Preset229=Preset229
Preset: Preset230=Preset230
Preset: Preset231=Preset231
Preset: Preset232=Preset232
Preset: Preset233=Preset233
Preset: Preset234=Preset234
Preset: Preset235=Preset235
Preset: Preset236=Preset236
Preset: Preset237=Preset237
Preset: Preset238=Preset238
Preset: Preset239=Preset239
Preset: Preset240=Preset240
Preset: Preset241=Preset241
Preset: Preset242=Preset242
Preset: Preset243=Preset243
Preset: Preset244=Preset244
Preset: Preset245=Preset245
Preset: Preset246=Preset246
Preset: Preset247=Preset247
Preset: Preset248=Preset248
Preset: Preset249=Preset249
Preset: Preset250=Preset250
Preset: Preset251=Preset251
Preset: Preset252=Preset252
Preset: Preset253=Preset253
Preset: Preset254=Preset254
Preset: Preset255=Preset255
Preset: Preset256=Preset256
Done
Wow that has found everything and looks correct. Might be worth an email to Ken if nobody else has that camera to give some more guidance.
Looking at it again, I wonder if there isn't a substream, so what is happening is on multicamera view it shows one camera and when you solo it shows the other?
Maybe leave substream blank and then add another camera (same IP) and for the mainstream select SecondStreamProfile and see if that gives you what you want.
