cooling fan replacement on dahua nvr
AlbertoIt
Jul 19, 2018
190
15
italy
Hi folks, i would like to replace the noisy cooling fan of a dahua nvr4208-8p-4ks2.
Any suggestion? (i don't want to modify the case, just to replace the fan with a quieter one, if it exists...)
Inviato dal mio Redmi Note 3 utilizzando Tapatalk
Reactions: AlbertoIt
Understood. Sometimes there are power supply fans and then case fans.
The bottom line is to get the correct size and voltage of the fan you want to replace and look for the compatible Noctua replacement
Sent from my iPhone using Tapatalk Pro
Hi did you ever replace your fan?
I'm in a similar situation. It's the power supply fan I need to replace, this one..
