D dimuc n3wb Apr 30, 2017 18 0 May 3, 2017 #1 I would like to connect a laptop to my NVR, do I need a cross over cable or will a standard RJ45 do the job? Thanks
fenderman Staff member Mar 9, 2014 36,891 21,418 May 3, 2017 #2 dimuc said: I would like to connect a laptop to my NVR, do I need a cross over cable or will a standard RJ45 do the job? Thanks Click to expand... its 2017, you never need crossover cables, throw them out..
D dimuc n3wb Apr 30, 2017 18 0 May 3, 2017 #3 Hi @fenderman I am trying to connect my laptop to the NVR so that I can try and access my camera (vi browser) using the x.x.254.xx address do you know if this is possible and if you could share basic steps.
alastairstevenson Staff member Oct 28, 2014 16,473 7,231 Scotland May 3, 2017 #4 Enable Virtual Host, then you won't need to mess with any cabling. Network Configuration, Advanced Settings, Other - tickbox. Reactions: dimuc
