- Nov 30, 2017
- 187
- 96
Hey folks,
I continue reading the cliff notes to gain more understanding. Each time I read, I understand a bit more of cam technology.
referencing these two models:
between the turret and the wedge, these two models, they appear similar in FOV. Their form factor is different, HDBW4231 being smaller. Would it be safe to assume that if I was to install the wedge, I would expect similar picture quality results as the turret, for both day and night time ? If that is true, would it safe to say that I can just install the wedge all around, instead of the turret? If that's not the case, what am I getting more from the turret, in terms of pic quality that I may not get from the wedge.
apologies in advance, if I am overlooking something obvious that would differentiate the two cams
cheers !
IPC-HDW5231R turret 2.8mm FOV 110 deg
IPC-HDBW4231 - wedge 2.8mm FOV 110 deg
cheers !
) of the wedge and would have like to use it all around but I guess one shoe does NOT fit all
