CCTV, any need for cooling on NVMe memory?
toastie
Getting comfortable
Sep 30, 2018
268
91
UK
My HP EliteDesk SFF W10 BI manages 6 cameras ( perhaps 2 more added later this year) has CPU load often less then 15% (thanks to me overcoming HP's grip on my Intel graphic driver install process).
I seem to remember adding a thermal conductive pad between the NVMe and the mobo, all sorted then, no need for cooling fins?
Then a wide general question, how important is the need to add cooling to NVMe SSD generally on a desktop PC that's not used for gaming?
Its not needed unless you are hammering the drive in an Enterprise role. So long as you have normal air flow through the case with the built-in fan(s) you are good.
You don't normally put a thermal pad on the side facing the motherboard.
High-end NVMe SSDs, particularly those using pci express 4.0, should probably have a heatsink on them, but should still work without one especially if you aren't writing full speed for very long.
Reactions: sebastiantombs
Watch out, because you might make it worse by cooling it too much (Yes, really)
The flash needs to run HOT, only the controller needs the heatsink. Putting a heatsink on the flash can actually degrade performance
