- Jan 4, 2017
- 4
- 0
Hi Folks,
I have an installation case that i need to solve,
1. i need to install 8 IP Camera
2. We need to have two NVR on a separate room
3. first NVR will only show channel 1-4 and the second NVR will only show 1-8
my question is,
I want to use this scenario by using a separate POE switch that send the data to two NVR's. So all cameras will go into the switch (port 1-8) and port 9 will go to the first NVR and port 10 will go to the second NVR. The NVR that i want to use is HIKVISION NVR DS-7604NI-E1 that only has 1 LAN port.
I am kinda new in this IP CCTV. would that solution work ? I know i cant have only just 1 NVR because i need to separate the channel into 2 monitors.
Warm Regards,
my question is,
Warm Regards,
