F formycctv n3wb May 23, 2017 25 0 Sep 3, 2019 #1 Hi, I use the GMSS /IDMSS APP, I got a black circle. If we use the windows software smartpss is works perfect. model : DH-IPC-HDBW4421R Attachments 113.jpg 13.2 KB · Views: 16 112.jpg 10.8 KB · Views: 16 111.jpg 7.3 KB · Views: 16
K Kameraad Pulling my weight Oct 23, 2016 165 139 Sep 3, 2019 #2 The 192 adress is a local adress, this should only work on wifi. Otherwise you have to configure your wan ip, and: open the port in your router. Which is not recommended, unsafe. Or: setup a vpn. That way you can use local ip's Reactions: SouthernYankee and Python
looney2ns IPCT Contributor Sep 25, 2016 16,693 24,877 Evansville, In. USA Sep 3, 2019 #3 How to Secure Your Network (Don't Get Hacked!) | IP Cam Talk Reactions: blargrx
