- Dec 7, 2016
- 4
- 0
Hi,
got Dahua PSS working fine with some IP cameras (mix of 720p, 3MP.
Went and purchased another 2 4MP ones (QVIS / Dahua) and these can't be found. Tried changing data port from the default 5000 > 37777 but nothing.
The new ones can't be found via the software although I can run the 4MP config tool from the QVIS website fine and also set them up fine using the HIKVISION IVMS software (which won't work with the older camera's!!)
Would be grateful for any pointers
thanks
thanks
