Hey, I need a little help. In the apartment building I'm living in, there was a new camera System installed. There are 16 digital, analog, whatever cameras connected via coax to the NVR and 2 IP Cameras. I want to get the RTSP stream for the cameras. To view the cameras using the Hikvision software and to have a backup of the recordings.
For the two IP Cameras, I can access the RTSP stream without any problems. But over the cameras, not using the NVR. When I use the NVR, I get no stream.
Using Integration Protocol I added another user with Admin rights and even enabled ONVIF. RTSP is set to port 554. I even lowered the security setting for RTSP from digest to digest/basic. Same....
This is the URL I try to open.
rtsp:/user:[email protected]:554/Streaming/Channels/401/
This was the URL I found online. When I discover streams over ONVIF with BlueIris I get this URL Schema:
rtsp:/user:[email protected]:554/Streaming/Unicast/channels/101/
But even with this, I was unable to connect to the NVR. I tried using VLC. I tried BlueIris and I also tried ffplay.
Does anyone have any ideas?
