- Apr 9, 2016
- 34
- 5
Ok. so far I got pass the NFS recording....
Here is my scenario:
I have four Dahua IPC-HDBW2300R-Z and one synology DS215J at home. Synology has 1TB and its NFS is enabled, along with quota, permission stuff. All four cameras created folders in each of their own shares so it is recording. Locally a PC running Smart PSS (both the English and the international versions.) can liveview and playback.
Now I have the router open forwarding all set. Incoming traffic to port 37771 forwarded to port 37777 at the 1st camera, port 37772 forwarded to port 37777 at the 2nd camera, port, etc.
In the office, when I tried to use smart pss to remotely connect to all four cameras, I see all four online and I can liveview them but when I tried to playback, it will give me error message....
Can your Smart PSS REMOTELY playback your cameras that record to their local NFS?
COR35VET at another thread replied back:
You should check what it's trying to access with Wireshark, at home and at work.
Though it'd be better if you set up a VPN on your home network so you can access them over that securely.
I don't have my camera at hand, I'll check it out later with Wireshark, I'm also interested whether it's accessing the NFS share directly or through the cameras.
