I know I must be missing something easy here...
After init install and setup of the New Cam I changed the IP on the CAM. (Static IP)
I set up my Dahua cam thru my switch on say Vlan 70 (setup and test Vlan) to my laptop. .All works great.
I have changed the IP settings for the Cam to 198.168.73.XX . And set my BI adapter to the 192.168.73.xx net work.
Then I plug the Cam into anther port on switch. ( Vlan 73) with my BI machine and go thru chrome to open the Dahua Software...and get can not find the a Cam (took too long)
Should I have set my Laptop to the exact same IP as the BI when setting up the CAM ??
The Cam should be seen by my BI if on the Same Vlan and network ?? correct ??
Need some help here...
