I can't connect to my Dahua NVRs using Android or IPhone/Ipad.. it must be Windows based because of the plugins. Has anyone tried connecting to their NVRs via local network wifi using the Microsoft Surface Pro tablet that uses Windows?
I have a new version of SmartPSS.. but here's the weird part. It has almost same contents as the NVR menu except there is no way to access IPC Offline setting. Did Dahua intentionally remove the capability so maybe the robber won't be able to disable the IPC Offline setting? I have to connect to the NVR via local network wifi to change the setting but need windows based browser.
And oh.. is there a way to install a windows browser in the Android or IPhone/Ipad so can access the NVR via wifi?
