Cable Length Limits
Cam_SA
Nov 14, 2025
2
SA
Hi All
New to this forum
I have a HikVision DVR and 5 Cameras all connected using Cat5E Cable. I have 2 cameras that are around 40m away and these 2 cameras has quite significant signal loss however they still work fine.
I'm adding 2 more cameras which is around 60m away and I already can tell that the signal loss is going to be even worse so I want to find out if RG59 cable will be a better option than Cat5E of Cat6E
Thanks
"The maximum length you can run Cat5, Cat5e, Cat6 and Cat6a cable is 100 meters or 328 feet. The length limit for Cat5 also includes any patch cables, jacks or couplers that are connected in the run. For example, you could not run 100 meters of Cat5 cable between the walls, and then connect with a jack to another 10 meter cable. In terms of distance limitation, the 100 meters of Cat5, the jack and additional 10 meters of Cat5 are all seen as a single length of cable. It is recommended to only run the structured cabling (the horizontal cabling or the infrastructure cabling) 90 meters to give adequate length for end users patching into the network jacks."
edit: Credits to the author referenced above... Kevin Kantola -- Discussing Cat5 Length Limits
Reactions: JDreaming
Hi All
New to this forum
Thanks
Welcome to IPCT! :wave:
You said "DVR" and not NVR........so are the cameras analog and not IP and you are using baluns on the CAT-5e cable?
