D dave7108 n3wb Mar 3, 2016 26 7 Mar 6, 2016 #1 do i need discrete graphics? il be running 4 x 4mp ip cams. With a i7 4790 & 16gb ram win 10 64bit thanks
fenderman Staff member Mar 9, 2014 36,891 21,416 Mar 6, 2016 #2 dave7108 said: do i need discrete graphics? il be running 4 x 4mp ip cams. With a i7 4790 & 16gb ram win 10 64bit thanks Click to expand... No, you dont want it. You want to use the integrated intel HD. Your load could easily be handled by a i5-4590 available for 300.
D dave7108 n3wb Mar 3, 2016 26 7 Mar 6, 2016 #3 any way to decrease electricity use - would an i7 be better?
fenderman Staff member Mar 9, 2014 36,891 21,416 Mar 6, 2016 #4 dave7108 said: any way to decrease electricity use - would an i7 be better? Click to expand... Would probably be the same. The newer haswell/skylake systems are very efficient.
E Emanresu n3wb Mar 3, 2016 1 0 Mar 7, 2016 #5 Not putting in the discrete graphics card will save on electricity. The integrated graphics on the CPU will handle the encoding with no problem.
I ilikebike n3wb Jan 7, 2016 24 8 Mar 8, 2016 #6 If you're building a system you can also look into the S and T series of CPUs. Slightly lower clock speeds but improved power consumption. http://www.anandtech.com/show/8774/...ew-core-i3-4130t-i5-4570s-and-i7-4790s-tested
