- Sep 29, 2014
- 282
- 30
I meant to by a HP SFF…accidentally bought a MicroTower (HP ProDesk 600 G4 MT). It is a perfectly good machine, but it’s too big for the space I intended for it to live.
Since I’m stuck with it, I want to put a couple of extra hard drives in it. I can put one in the 5.25" ODD slot, but there is so much space in the case, I’m wondering if anyone has one of these and found a way to swap out the drive cage or mount additional drives inside?
The existing cage holds a 3.5" and a 2.5" drive, but with the way it is designed, the 2.5" space has a metal rail welded/riveted where a 3.5" could actually fit. The OS drive is a gum stick, so the 2.5" space is wasted.
Thoughts? Anyone have one of these already and figured out how to make it work with more drives?
