- Sep 25, 2017
- 3,133
- 4,045
As promised this is my PC Build Thread.
I'll divide into sections so if you want to you can skip parts that don't interest you (hopefully it all does!).
It's not intended as a definitive "this is the pc you need / must build". It represents my choices based on what I perceived to be the best value for money at the price point I was trying to achieve. Others may have differing hardware requirements and opinions on whether the right choices were made.
If you live in the USA, you may find new or nearly used ready built PC's bought by companies in bulk or replaced often after little use, represent better value than building. In the UK and maybe EU (unsure of the EU but it's often similar), these can be hard to find. In the UK at least, most companies only buy the exact number of PC's they need and often run them into the ground before buying new ones making the 2nd hand / refurb market more risky. UK buyers may also find refurb pc's quite expensive over here - not much cheaper than building so a double wammy.
Building was right for me because in my searches a similar pc refurbed wouldn't have been much cheaper and self building allowed much better control over the selection and quality of components and better future upgrade choices over many refurbed office pc's.
I also used the IP Cam Talk Store for my Blue Iris Licence to Support Fenderman and the community.
