Blue Iris no audio
JHooK
Jan 23, 2015
11
1
Hi,
I have IP cams:TP Link 7141 and DVRs: Dahua h.264 RSTP I`ve configured all settings but cannot hear any audio streaming, with SmartPSS audio works fine.
What I am doing wrong?
attachment.php
attachment.php
@JHooK Welcome to the forum. The blue iris options microphone audio settings are for when you use a mic to "talk" to a camera...those are not relevant here...
In the camera settings (your second picture) select "ip camera stream" not directshow..
Thank you,
I was trying before with IP camera stream, but in this case the video signal disappears and I receive an RTSP:404 NOT FOUND error
That should not be happening email support to let him know about the problem..are you running BI3 or BI4...if 4 and you are using 64bit, run 32 bit instead...
Reactions: JHooK
I`m using BI4 32bit now, very strange because from some cams I have audio signal from other no, I can guess this is because of no enough bandwidth to transport audio+video same time
I dont think its the bandwidth...if you have audio using the browser to login to the camera then you should get audio in blue iris.
Solved. For me the problem was in ports, I just enabled RTSP/UDP port and everything goes OK for all my cams.
Reactions: fenderman
